Well,start by filling the resevoir,re-install the cover and then pump the lever several times.Then check the fluid and top off if needed.The fluid had to go somewhere,so I suspect you have a leak.You may not have to bleed them.It would be a good idea to remove the front drums and inspect the linings and wheel cylinders.
