Okay. I bled the brakes.... still no resistance. I did notice that there was fluid on the ground when I pulled my ATV out of the garage. Obviously, there must be a leak, but really cant tell from where. Any suggestions?
You need to clean the bike so you can find the leak. I would pull the wheels & drums to check the wheel cylinders.If it's leaking you should be able to see fluid after repeated brake lever actuation.The only hydraulic parts are the master cylinder,hoses & the wheel cylinders.You do have a Y where the hoses split to go to each front wheel.It is a very basic system so you should be able to find the leak pretty easily if the areas are clean so you can see the fluid.Good Luck,MOON
