Ok fellas, A few more questions...How do I remove the bearing????? from the front or behind the knuckle assembly? I have removed the front dust cover and snap ring and the bearing component was shot and parts just fell out. How do you get the balance of the bearing out (I can still see the other half inside the hub)? I did not want to mess with loosening the tie-rods if possible and I can't seem to pull the "spline" (that that castle nut threaded onto) out the back of this assembly, there isn't enough clearance or room to work with. Any thoughts appreciated/comments appreciated...THX
PS: What do you recommend for bearings???? maybe sealed type in lieu of the open style...comments please
