i put on pipe and jet kit a week ago. i turned the air/fuel screw out 2 1/2 turns. went on first ride over weekend and my bike was "bogging down" in heavy water acting like it wanted to die. carb is clean and the drain line is plugged.
pulled my spark plug tonight and it is bad fouled. i used the right jet. now figuring i need to fine tune the screw to help the plug. which way do i need to turn it and how much.
would this cause it to run crappy when in water. i put dielectric grease on everything i took loose. thanks for your help.
