After lunch today I was going to round up some limbs that fell from a recent hurricane. I remember the last time I used my foreman I was unloading some horse feed and I had to use the reserve on my tank, I just used it and then parked it. This was two weeks ago. Today I filled up the tank with fresh 93 oct. fuel before attempting to even start it, all the bars on the fuel level indicator lit up and is steady blinking. I switch it to "on" and nothing. Switched to "res" nothing just dies out if I don't stay on the throttle, or choke it.
I hope someone can help out, if not I will start researching the carb. I don't have a service manual so if anyone has any links that would be nice.
I can only make sense of the tank running low and maybe allowing some sort of deposit to enter the carb? Again, it will run fine with the choke on or throttle engaged. When either is released it will sputter and die.
I hope someone can relate to the problem.
Rob
Rob
