So 2014 trx 500 fm1
Turn key on an nothing on the dash it’s blank. Checked all fuses, relays clean no corrosion. Good battery. Unplugged key switch made a 3way jumper an it fires up an runs great. Dash works perfect.
So I replaced key switch. Still broke.
I’m starting to wonder what’s going on could the starter selinoid be defaulting or neutral safety switch??
Need help!!
Do you have the manual on this, you may be able to locate with the link in my signature, sorry I haven't looked for that particular one even though I should have, I have some model and year. With the manual, I would check the plug closest to the problem area and work my way towards the battery checking for voltage (12V) towards the battery source following the wiring diagram in manual.
