Okay, multiple pics so I will make multiple posts
1. Straight out of the air box with a piece of 2" shop vac hose.
I've had mine very deep w/o a snorkel. Since Everyone around here has one. You have to be sure to grease the sparkplug, run the carb ventlines to the headlight pod and plug the carb drain. Those are musts if you want to run deep.I have an 05 Foreman that drowns even when yer into the throttle. no water in the airbox, so I must be getting it up into the muffler. I like your snorkel, but I don't have the engine dying like that on the rancher. If I'm in the throttle, how does the water get in?
QUOTE ("the_budman":qwxhup8c)
I've had mine very deep w/o a snorkel. Since Everyone around here has one. You have to be sure to grease the sparkplug, run the carb ventlines to the headlight pod and plug the carb drain. Those are musts if you want to run deep.[/quote]I have an 05 Foreman that drowns even when yer into the throttle. no water in the airbox, so I must be getting it up into the muffler. I like your snorkel, but I don't have the engine dying like that on the rancher. If I'm in the throttle, how does the water get in?
