Foreman 500 clutch
3.4K views 4 replies 5 participants last post by  BigDogDaddy
#1 ·
Can someone explain how the clutch system works. Is it centrifugal with plates or what? '08 with manual shift.
I'm wondering, because I use mine for farming and would like to know if it will harm (wear-out faster) if I leave it in gear (1st or 2nd) with the engine running for a minute while I'm off it. This might be done 20 times a day. Or would it be the same as in nuetral with engine running.
Thanks,
Gayle
[attachment=1120:072409.jpg]
#2 ·
no it wont hurt it. it has 2 seperate clutches in it. the primary clutch works off of weights and springs in side of a housing. when the engine speed increases the weights spread out and grab the outside of the housing turning it which is attached to a gear which turns another gear that is attached to the secondary clutch that has disk and pressure plates held together by pins and a spring keeps the tention on it this is the adjustable one that uses the screw on the front cover to adjust it.
#3 ·
heck no...dont harm nothing....done it a million times.
#4 ·
the only time it will hurt anything is if your idle is set too high and the bike is sitting there twitching or jerking, because the clutch is half engaged
#5 ·
QUOTE (98greensi @ Aug 11 2009, 10:46 AM) index.php?act=findpost&pid=132460
X2....otherwise you will be fine ;)
