Me and my dad recently bought a 1998 foreman 450es that has shifting problems in higher gears for example,when you drive around in 1st,2nd,3rd, it acts fine but if you shift into 4th and 5th and speed up .the electric shift stops working (not always but most) and will not go up or down in gears with the buttons.But if you use the manual shifter from the tool kit it shifts fine.The screen is busted and not repairable it does have a new shift sensor,shift motor,battery and tires put on by the last owner that had it worked on by the Honda dealer with genuine Honda parts.I did notice the screen was unplugged and just sitting there,I noticed I cannot get a new screen for it (due to them being discontinued) the buttons on the handle bars seem to not be corroded on the inside nor burnt.The last owner also said that the dealer had a machine like this 98 in also and switched their screens and the recently bought one shifted fine.it also has other issues such as a ripped swing arm boot,leaking main seal and the baffle is broken in the exhaust causing it to be extremely loud . Does the screen effect the electric shifting if it does or doesn’t what could be the problem any help is thanked.
