I just had my carb rebuilt and it runs great except when I turn the fuel cutoff to either on or reserve I begin to leak fuel from a line from the carb. Has anyone had this before and if so how can I fix it? I appreciate all help in advance. Just trying to get it working so I can start getting a better deer stand built.
welcome to the site
first off, what yr is this atv?
as they stopped making 400 foreman's in early 2000's
so there is NOT a 2014 400 foreman?
but any ways
if the fuel line is leaking, , I think you need to replace the old line with new trygon yellow fuel line(this is ONLY ethanol approved fuel line I know if, the black, clear/blue stuff is NOT ethanol rated)
fuel line is cheap and easy to replace
shut fuel valve to OFF< pull line off things replace with same length line, turn fuel back on and see if it solves your issue?
IF not, the odds are , if NOT the fuel line that is leaking/bad, but your carb float is sticking causing float to hang up, and fuel to over fill bowel and this leak out over flow vent
