for all of you that are wontering how the the kenda executioners do this is for you. this friday i got them mounted up on interco condor 7 spoke wheels. i tryed them out in a field where a spring came out. the ground was real soft and was verry easy to bottom out in. the tires did real well going through the spring ecept when i would bottom out but besides that they did great. they cleaned out good also. on trails from what all i went on they did good. the ground was kind of loose on top but hard under that. all you had to gas it and they went but they did tear up the ground when i went fast but when i just putted arround on the trails they didnt tare up the ground at all. executioners are just like 589s but are more agresive. the executioners have a REAL rim saver and is a very nice feture! they have 1 1/2 in. of tread in the center of the tire and as it goes out towards the sides its 2 in. if any one has any more questions about them just ask. ill try to answer all the questions you have.
-Aaron
-Aaron
