I had my bike out and it had a malfunction or something because it very suddenly stopped and wouldn't start or anything, I pulled it home and I wasn't getting spark and the ES system refused to budge, somehow the spark started working again but the ES still refuses to do anything, it's not the wiring or shift motor, I've tested everything, in down to either the gear position switch or the ECU, I couldn't get any ground through the switch aside from the grey wire, I opened up the case and the module itself looks perfectly fine, what can I do to verify its the switch or the ECU because I'm at a loss, much more of this and I might do the es to s conversion
Does it shift manually fine? Is the neutral, reverse indicators displaying correctly?
It seems to, little gummy almost but I think it's just from the shift motor, and yeah all the indicators work as they should lastni checked
