engine problem. help needed!!
1822 Views 1 Reply 2 Participants Last post by  Honda Mechanic
Hey I have a 2001 honda 350es and the bike has a tapping noise comming from the motor. i though it was a loose valves at first, so i took the valve cover off and checked the valves at TDC and the intake was off a bit so i set it and still the bike is making a tapping noise. I know its hard to say what the problem is but a few ideas may help me out.
Thanks, Chris
Myself I'd check the top end first cause it sounds like the piston is scuffed also check the wrist pin..
