Rich was just wondering if you are using oil that is JASO certified for a wet clutch. Not just the oil you use in your car as most of that oil is energy conversing and is not to be used with a wet clutch as your wheeler has a wet clutch!!I'm not sure what you mean about the oil in the wheeler wet clutch. Yes, it will down shift manually Rocking machine doesn't help.
yes ....i don't make this shitt up just to fuk with people ....Really on that Rich? i have been using 10w30 dino oil in both my 450s and my 79 cb650 and the motorbike has wet clutch also. The streetbike get used more than my wheeler but shifts fine and i only check my clutch adjustment once a year on that....between the oil and just getting my adjuster fixed on the 450; should i go to the JASO-MA?
Or is this just a wet clutch specific type? Will research it and find out a Canadian price as i am from the cold white north.
