Cleaned the angle sensor and re-installed it and it shifts like new, believe me the plastic is the worse part of this job, now since I am feeling pretty confident I am taking apart the left side and pulling the carb so I can see what size the main jet is I am not looking forward to the air cleaner housing with the 2 inch snorkel I have a new HMF basic jetting kit and feel like I will try the 170 main jet depending what is in it, Surely it was rejetted when they put the after market exhaust and custom snorkel but you never can tell so the only way to know for sure is to take the thing apart and look! I have a slight hesitation low in the throttle but top end seems fine, My question is the main jet the only one that needs changed, Idle is a little sluggish to but the main jet control's from half throttle to full throttle so a little confused I may wait for a reply before I pull the carb, it is so nice to be able to down shift again my confidence is restored in Honda's Electric shift program. I am a little hesitant to adjusting my clutch it seems strong, does this need adjusted more on an es model because my father inlaw has a 2000 450s and has never adjusted the clutch. thanks
