I bought a 2" lift kit off of ebay and am having a bitch of a time installing it. The RF piece did not line up correctly and I had to make the hole that goes over the RR bushing a bit larger to fit.
<a class="postlink" href="http://cgi.ebay.com/ebaymotors/2in-LIFT-KIT-for-HONDA-RUBICONS-FOREMAN-500-LKH3-3_W0QQcmdZViewItemQQcategoryZ43982QQihZ007QQitemZ170139375206QQrdZ1QQsspagenameZ
WDVW">http://cgi.ebay.com/ebaymotors/2in-LIFT ... enameZWDVW</a>
I finally the front pieces are on, but does anyone have any suggestions on how to install the rear pieces? I completely took off the RR shock and installed the top of the shock and lift bracket. Now the bottom of the shock is dangling down and I can push up the body high or long enough to set it into place.
I need to get this sucker installed before Thursday as some friends and I will be hitting up the dunes.
Am I going about this wrong? Would removing the LR shock at the same time make it easier?
Any tricks, tips and/or suggestions would be greatly appreciated.
Thanks.
Thanks.
