same here...doesnt really run the good at top end and defitley not gettin all the power out of it that i cani run a DJ134 in mine and it does good but sucks the crap out of gas so i think i am going to try the OEM 135 and reposition the clip on the needle.
Thats the setup I have with the dynojet 134. Mine also uses a lot of gas.i run a DJ134 in mine and it does good but sucks the crap out of gas so i think i am going to try the OEM 135 and reposition the clip on the needle.
hey railroader, have you done a plug reading? does the burn look ok? is it rich, lean, or just right?That's what i did to both of ours after several other experimental jettings &
that set up worked the best.
