disc brake custom upgrade for the RECON ,also a easy cheap rear lift bonus
i put disc brakes on the front of my 04 recon and got a lift for free. i used all honda parts and it cost me $250. I started by going on ebay and finding 99-05 trx250ex spindles,hubs,rotors,calipers,shock,etc . also i needed a rear shock because mine was shot so i bought a 250ex shock also. I bought new rims and (tires 23x8x10 are great) to fit the new hubs bolt pattern. Then installed everything and re-did the brake lines in a different route ,redo the tie rod lengh and bam done. i then installed the rear shock which was 7/8" longer and now the rear has a lift. the front spindles are also lifted and the only thing i need to work out is bleeding the master cyl and brakes. i drove this atv for 120 miles. its great and taller.email me if you want pictures , [email protected].
i ve been working on this for a while and now its all done and works great.
