1 - 1 of 1 Posts
I believe I have a superatv version of disc brake kit, whoever did the install didn’t reroute the brake lines so they were sitting on the steering joint and kinking when turning. I also wanted to clean up the parts so I disconnected the brake line which was a big mistake. The banjo bolt had some type of aluminum and rubber washers which I’ve never seen, went to part store and got copper ones, found out that the bolt was now too long because the copper washers were thinner, got a different set of banjo bolts to fix that issue but I CANNOT get the bolts and washers in any combo to stop leaking, I’ve used about 3 pairs of washers now and it always leaks and a pretty good leak at that. Anyone have this problem. Anyone know the correct size and name of the factory or superatv kit crush washers? Any tips would be helpful!
1 - 1 of 1 Posts
