How often should you change your differential oil?
How true and you cant even screw that up because you put enough in so that is comes out the check hole in both diffs. If you have a swing arm skid like I do you will need to remove it or modify it like I did. Also as Eurobro said the front is harder with the stick guards but a real PITA if you also have a bash plate.Simplest thing in the world. Just make sure you put the correct amount in
there.
