Hello all, new to the page and ATVs in general. Just picked up a 2003 Trx450es for cheap. It did not run but was in otherwise great shape. I pulled the head after it wouldn't turn over with the recoil starter. As I suspected, the piston was being blocked by what seems to be a broken valve seat. Ordering a new head and top end kit already, but is this something common on these? Is there something that was neglected to cause this? There was plenty of clean oil in the motor, no clear signs of abuse. Is there anything in particular that I should be aware of for these machines? From what I've read they seem to be pretty rugged. Thanks for any insight!
49195
About a 2% failure rate I would say. My best guess is heat or bad materials.
Thanks for the info! Hopefully this next head will be hardier. Looking forward to putting this machine to work
Discussion Starter #4
So I purchased a used complete cylinder head on ebay off of supposedly a running engine, they bead blast it and check it apparently. I noticed some deformities, but I'm not sure if they would cause any problems. Should I be trying to get a replacement?
49250
