It shows the ball joint tool ..We have 1 but it only gets used a couple of times a year .. The ball joint is a taper fit ..if you remove the cotter pin & nut then hit the side (where the taper ball joint goes thru the knuckle) they will pop right apart..
Ok Neil. what do you use to hole up your pants?? Duct tape??
I have heard of using "liquid tape" Its for insulting wires so it should be at most hardware stores, it looks something like a PVC glue can. I just couldn't on how long it will last. CVs are too expensive to "rig" something IMO. But then again I'll try anything once!
I changed mine by removeing the 2 upper A arm bolts, and the lower shock bolt. and the Axel nut there was enough clearance this way to remove the axel and change the boot. Also I recomend using a torque wrench on the castle nut. 58 ft lbs
1 - 12 of 12 Posts
