Did a big search here and on HL. Getting conflicting info. That nasty crank case vent line that comes into your airbox with the the little filter on it - what's the best way to waterproof this? I
keep reading about 'looping it up over the airbox' - maybe it's me but I just don't get how that will work? I've also read where you take it and 'loop it around your gas tank'? Huh? Does that mean you take a new line, attach to your bottom end, loop that around your tank and than reinstall it in the same (stock) place, the little foam filter coming from the bottom? Is that right? So that means you create a 'high spot' (around the gas tank) and than loop it back under the airbox and reinstall in the stock airbox opening?
Dam, I'm confused.
Dam, I'm confused.
