Cracked Rear differential
2247 Views 2 Replies 2 Participants Last post by  vettepin
Cracked the top left side of my rear diff ( with a partially popped bolt) during a trail ride this past weekend. Is there any tips or tricks that would help getting the diff off, checking the gears, replacing seams and O-rings...???
Just want to make sure that I don't miss something while I have it apart.
Thanks for any help on this one!
Bump.
No one has had this happen?
you need to check backlash on the gear set and check for broken teeth and a bent case. i would buy a new rear .
