I cant figure out why my fan will not work. Can anybody tell me what to look for to fix it.
H Hondaman · Registered Joined Feb 9, 2006 · 18 Posts Discussion Starter · #1 · Apr 18, 2006 Only show this user I cant figure out why my fan will not work. Can anybody tell me what to look for to fix it.
E eustismudder · Registered Joined Mar 23, 2005 · 438 Posts #2 · Apr 18, 2006 Only show this user Check your fuses.
dirty4man · Registered Joined Mar 6, 2005 · 2,679 Posts #3 · Apr 18, 2006 Only show this user also look to make sure the wire hasn't come off the temp. sensor on the rear bottom of the motor under the pull rope assem.
H Hondaman · Registered Joined Feb 9, 2006 · 18 Posts Discussion Starter · #4 · Apr 18, 2006 Only show this user Ok I will try that thanks
R Railroader · Premium Member Joined Jan 18, 2005 · 3,337 Posts #5 · Apr 18, 2006 Only show this user That happened to my wifes. I took it in & all it turned out to be was a stick had somehow got up in there & somehow unplugged the wires.
Honda Mechanic · Registered Joined Jul 31, 2005 · 1,236 Posts #6 · Apr 18, 2006 Only show this user Did you try grounding the sensor wire to check if the fan works ..?
