yes, i only have 26's as well, The clutch kit adds to the fun factor, and for me made it possible to wheelie again. However i will give you some advice for installing the clutch kit. That is if you plan to do it yourself. I did, and all i have to say is that you need to use the right tools. Me i only had available a straight pair of needle nose. It made stretching the springs alot harder. Using a pair of long 45 or even 90 degree plyers would have made it easier. Also you had better plan on getting a new seal for the front of the crankcase. I figured like all the other hondas i have owned int he past it would have been honda bond but was not. And don't try to reuse the seal you will probably have to take it apart and re do it causing you double the work.
And one other thing. Most will say to remove the clutch, however if done carefully you can stand the atv up on the back rack and remove the plastic as directed and you can easily change the springs that way. This is how I did it. If you want to see some pictures there is a post in the how to section. That is not my post but it will definitly get you headed in the right direction.
Hope i helped
