1 - 10 of 10 Posts
i got a epi clutch kit for my rubicon a while back. i was wondering if the kit made it harder to shift in esp. i have to push up or down about 3 times for it to shift. is this normal?
Thanks,Aaron
It should not affect shifting. Like Euro said, did you mess with the adjustment screw. I played with mine a bit and got it out of wack. but it was pretty easy to get it adjusted correctly again.
Discussion Starter · #4 ·
i dont think i ever messed with it. it will never hurt to look, how do you check it?
There is an adjust ment screw on the front cover you removed to install the clutch. It has a jam nut you must loosen. Then with a flat screw driver you can tighten and loosen the clutch.
Discussion Starter · #6 ·
so your saying its in the motor on the cover on the clutch? because im looking in my dads service book and all is says there is is the lock nut and thats all.
Discussion Starter · #8 ·
ok thanks i didnt think there was but i thought i was wrong thats why i looked it up in the service book. does anyone know what the problem is then? i know alot about hondas but i have only messed with clutches only a couple times and dont know much about them.
Thanks,Aaron
Discussion Starter · #10 ·
eustismudder i never thought of that and that may very well be whats wrong.
1 - 10 of 10 Posts
