underneath the motor you should see a drain plug...take it out and drain it...maybe jack the front end up a little bit to get most of the oil out...on my 2002 the oil filter is on the right side of the bike as you are sitting on it right above you foot on the side of the motor...mine is a little round cap with i believe 3 screws...make sure you put the oil filter back in the right way or you could screw things up bad...it will say which side goes in...basically just like doing your vehicle...good luck
when you're checking the level, while adding fresh oil, make sure you don't screw the dipstick in. the shop manual states that the level be checked by resting the cap/dipstick on the top of the threads - not screwed in. also, make sure to use the correct oil!
