I can't find this in the owner's manual of my 06 Foreman ES, can you (or should you) shift from 2 wd to 4 wd while moving or do you need to stop to avoid damage? If you can do it while moving, how fast can you be moving when you go to 4 wd? Thanks
you can at about any speed. i know the rpm's have to be low, so spinning tires and it engaging isn't much of a possibility. if it doesn't engage immediately you can leave it in 4x4 and it will engage when the conditions are right.
I switch mine whenever I want to. I know on mine it will engage/disengage at any speed as long as all of the wheels are going the same speed. The fastest I've done it is probably about 40mph but i have to let off for a second before it will engage/disengage.
You can shift in/out of 4wd anytime you like but the ECM won't actually shift unless there is less than 10 KPH speed difference between the front & rear axles ..
1 - 10 of 10 Posts
