use some T's to save hose and space, both carb lines= 1, rear diff. and brake= 1, fan and front diff.= 1.
and the sizes are
1/8" tubing and barb connectors for the diffs and the rear brake and 3/16" tubing and barb connectors for the fan
the hose off the fan is a pinkish clear the rest are black
you can get all this from lowes, or home depot, it will cost more at an auto parts store
o and i use a golf tee to plug my carb drain and i extended the hose for easy access and keep some extras on board.
and i forgot to mention on the carb drain there is a little black check valve pull it off and throw it away. they are cheaply made the gasoline eats the seal the first time it hits it.
