I finally extended my carb vents up to the light pod, but here is the problem I tee'd them into one line and ran it up to the pod. when I went riding and got in to some water about floorboard deep it started spuddering and shut off. My carb drain was not plugged so I thought that may be the problem but when I got home on dry land it was still doing it. So then I thought it was not getting enough air so I split them up into two seperate lines. It is now running a lot better but if i hit the throttle hard or quick there is alot of hesitation before she takes off.
Any Ideas?
Any Ideas?
