Are the carb vent lines everyone runs to the light pod the ones that are short and are hooked together and pointing down running through eyelets attached to the carb? One looks smaller than the other also.
Yes, they are on the opposite side of your carb from your airbox. You should also plug your carb drain tube. If you look at the bottom of your carb you will see a line running down to the frame, thats the one you need to plug with a screw or something. But remember to unplug it if you are trailering or in the bed of your truck on a long ride.
