carb vent hoses
2441 Views 2 Replies 3 Participants Last post by  foreman68
the two vent hoses that are right on the carb..... can they be vented to the air box??
Best thing to do is. GO to ACE hardware or anywhere that sells close to that size of hose, buy a T, and run a line up to your headlight pod, easiest way, no drilling and no having to worry about a good seal on your airbox then. very cheap and easy to do
As stated by the other reply the best way is to runthem to the headlight pod or snorkel. The barb fitting you need i believe is a 3/16", the 1/8' is a little loose.
