i recently had my top end rebuilt...well the entire engine was pulled from the frame and they tore it all down and scraped out mud and sludge from the bottom of the motor then cleaned it all up and put it all back together and bored the cylinder for the final time and put new piston/rings on it and then he adjusted my valves and rejetted my bike, not sure if he when he rejetted it he went down or not, i think it was a 170 jet before i brought it to him, bike runs good other than it wants to take off at half throttle...i have just recently put a clutch kit in the bike and was wondering if it is a carb problem or if the clutch kit makes it do this but at about half throttle in every gear you can feel the bike catch or something and take off...not sure if the clutch kit makes it do that or if the carb is not jetted correctly, cuz isnt there a jet for like idle speed to 1/4 throttle then the needle covers from 1/4-1/2 throttle then the main jet goes from 1/2-full throttle or am i backwards on what jet or needle is for which throttle spot...anyways not sure if the needle just isnt set in the rite spot or if the main jet is too low or if its a clutch issue, when i installed the kit i did not adjust it at all
