Pull in front brake (Right Lever) and it will start in all gears. Even Reverse. Just remember that if you use the throttle to get it going it will go into "Limp" mode. Acts like a two cylinder engine running on one cylinder. If this happens, wait a while or just shut off and restart. You should not need to use your throttle to start, if so, choking it would be better. Just thought that I would pass it on since it happened to me and I was curious at first as to what was causing it to run so poorly. Just a built in safety feature so you don't take off unexpectedly.
Bruiser
