front and rear diffs front and rear brakes fan carb i think there are 2 carb vents on your 500 not sure but thats what ive seen in pics you will see the tubes alredy comeing off the diffs brakes and fan just run them higher but extending them wiht either new tubeing or get a connector the carb vents you canr run into your snrok but the others you can just run the carb lines up to your pod
