If you want brake lights on your honda, here is how I installed mine .
I wanted the micro switches for the hand brake levers, I got the part numbers from a Honda dealer microfiche.
The switch p/n is 35340-ML4-005.(needed 2 of them 1 for each hand brake @ $11.17 each)
Also needed was...
1 stop switch collar p/n 35345-HF1-830 ($3.78)
1 screw-washer (4x20) p/n 93893-04020-07 ($.55)
1 screw-wasger (4x14) p/n 93893-04014-07 ($.50)
I am too cheap to pay the $100 plus for the "Honda Brakelight Kit" and have already run the wiring and added a "brake light"(actually two side marker lights bolted to my trunk door, or next to it.) All told it has cost less than $35.00 this way.
I have done 2 Recons(97&2000), 1 Rancher(2001), and 1 Foreman 450es(2004) with these parts. There is also a foot brake switch available, but I have not ordered it or installed it yet.
Note: I have only found the "Honda Stop Lamp Kit" listed for the "97-98" Recon and it says "Maine Only" on the microfiche.
I hope these part numbers will help others.
With these part numbers any Honda dealer should be able to order them. (I have ordered from 2 different dealers) If anyone needs to know who I ordered these parts from P/M me and I will send you the name and phone number of the dealer.
Here are some pic's of the switch install. You may have to register,(free), and sign in to see the pics.
I hope this info will help others.
Also needed was...
