Hey Everyone! I have a problem that I cant seem to figure out. Ill start of with details. 2001 Honda Foreman 450 - 3300 miles.
For some reason while I'm riding the bike will start making a hissing sound in the front and the exaust will stop making noise. While this is happening it will bog down and loose power and sometimes even slow to a crawl and stall. Sometimes if I let off the throttle or flutter the choke while this is happening it will start running fine again for a short time. The hissing in the front sounds like someone put their hand over the air intake and the exaust literally goes silent like it was plugged. The first thing I thought was it must be the carb. I have made sure that all the fuel is flowing fine up to the carb. I took the bike to a mechanic and had him give a really good cleaning to the carb and make adjustments to the valves. I have cleaned the air filter and checked the spark plug. Everything seems fine. It really seems like something is plugging up every time it boggs down. I had the mechanic take off the muffler to see if maybe that was the problem, ( something like a rock that bounces around and plugs the exaust from time to time I thought ) The muffler is full of rocks and metal peices. I had tried to run the bike while the muffler drain was open but nothing came out. Anyway, I was wondering if anyone has any idea of what it could be and also if i should replace the muffler. Thanks for your help
