Battery Keeps Going Dead
5316 Views 2 Replies 3 Participants Last post by  manfordm2
I have a 2012 Honda Rincon 4x4 that keeps dying. Could it be the alternator or something drawing on the battery? I can charge it and it will last about 2 days if that and then the battery will be completely dead. Any ideas?
Welcome to the forum.
How old is the battery?
You can take the battery off and have it load tested.
If the battery is good, remove the negative battery cable, hook up a test light between cable and - battery post, and it will likely light up. If it does, that means you have a drain.
Start pulling fuses until the light goes out, and that will tell you which circuit the drain is on.
what if when you pull the fuses, the only one that kills the light is the main 30amp???
