your right they were very tired and wanted to go home but i didnt so i said first a photo then one more load then we can go homenice looking trailer but the logging crew didn't look to happy to be there.
MAN! That's an awesome trailer! I built one for the same purpose,hauling logs out of the woods.One problem with mine is loading the logs onto the trailer,Heavy logs are a pain to lift over the side rails.I thought about using pipe to make a roller on the rear so that you could load them from the end.
where did you get it?
Here's what I built. Same track width as the bike with lots of ground clearance. Plastic tub can be removed for hauling logs. Or left in place for cut wood or gravel. Also makes a great Mobile Hot Tub.Aynone else have pictures of their homebuilt trailers?
The tub is from an old "tilt truck" used for bulk material. This is a pic of a trailer we use to give the kids a ride.Nice trailer H4. Where did you get the tub from?
