Mine came the same way. I talked with HMF over the phone because I had read about changing out the needle, spring and such with the Dynojet kits. They told me that all is needed was to change the main jet and adjust air/fuel screw. Granted I wish they would send a wrench to turn the screw, I just worked it out and used a dremel tool to cut a slit in it so I could use a flat screwdriver.i just got one and actually just put it on tonight...
came with, k&n filter, prefilter, jets, hmf exhaust....
i have a few complaints though.... jets didn't come with any tools to adjust fuel screw, no springs or anything, just the lets in a plastic bag....
oh yeah and no instructions.
the only instructions i had were how to remove and install the new exhaust which was a no brainer if you have any common since.
but other than that, i got the kit in about 5 days. took two to install it.
so far so good.
Yes, Dynojet sends one with their jet kits and I often wondered if you could just oder the tool from them. Might be worth a call to someone who hasn't gotten their performance kit yet. I didn't realize I needed the tool until I had everything tore down in the driveway and had to improvise.dose anyone make that speical tool for the air/fule
