1 - 5 of 5 Posts
Hey ya'll, my father and I put a carb kit on his 85 Honda 200s atc 3~wheeler
and we're having trouble adjusting it and its running rich !! We set the idle,
and put a hotter plug in it, and it still runs rich !!! My ???? is, is there a way to adjust the jets or something!!! I'm open for any sujeastion !!!
Need to adjust the air fuel mixture screw, if it has one. The new honda's is a brass moon key. Or else you need to change the size of the jet!
Discussion Starter · #4 ·
QUOTE ("putang59":2t4rbiex)
Where would the air fuel mixture screw be at ?? Cause I keep pictureing
the idling screw....
I believe it is on the left side of the carb when you are sitting on it. You are suppose to have a speciel tool to adjust it, but a flat screwdriver will work.
1 - 5 of 5 Posts
