AStuck Choke Plunger
4899 Views 1 Reply 1 Participant Last post by  cgm1518
G
Is the a quick fix for a stuck Choke plunger?
The plunger has a rubber cover for a nut that u can adjust the tiightness of the plunger "cable". I had a problem that the choke wouldnt stay choked so i tightened it down a little. u might loosen it up or take it off and put little lub in it? unless its stuck it the carb!
