Well I didn't want to jam a nut in reverse cable because I want to use brake lever to engage and tried the washer but the parking brake didn't work very smooth. Took handle off and drilled a hole in the bottom of the R pin. Put lever back on and pushed the R pin down through the reverse cable mechanism. Put a black self tapper in the hole I drilled in bottom of R pin and walla. I have to pull back on brake lever like I wanted and if I don't like it I can just remove screw.
