Adjusted the valves to spec today. Engine was at TDC on Compression stroke. Now when I first started while it was cold, there was a chirp sound when I let off the gas and went back to idle. Once in a while when I shut it off it did the same chirp. After the bike was warm, 5 mins of riding, the chirp sound went away. Washed the bike, started it back up, chirping again. What could this be? Too tight? Too loose? Should I readjust the valves again?
Sounds like they are too tight ,go to the how to section and follow the steps,I found the best temp for setting them is room temp .Was it hot when you set them?
Honda Foreman Forums
