If I let it sit for awhile it will start and run for a few seconds then die. and not crank again. Until it sits a while again.🤬
I bought one from harbor freight but it doesnt fit the small spark plugs. I can't seem to find one online that says it will fit the smaller ones. But I will check with advance.I'm going to suggest that you go somewhere like Advance Auto, O'REILLY'S or some other auto parts place and get an inline spark tester. The one that plugs onto the plug and into the plug wire. That way you can see immediately if you've got fire at least to the plug when it quits. You can run it with the tester on there.
Any follow up on this, I took the top off my carb and pumped and I would get fuel but seemed to be somewhat plugged as if not getting solid flow, replaced then starts and it would die. tried pouring gas into the carb and same thing. Replaced cab and still having the issue. Not sure if it being a new carb now may need something adjusted?I bought one from harbor freight but it doesnt fit the small spark plugs. I can't seem to find one online that says it will fit the smaller ones. But I will check with advance.
