I have a 87 350d and it is miss firing? running rich it always starts right up no matter what weather even in 20 below weather but it misses maybe light spark? cdi going bad? I changed the carb out to a 350x carb and its still doing it I have the carb soaking in chem drip now and I have a rebuild kit I will put in tomorrow I heard I can only use a 87 cdi box for my 87?
I've got a slew of 350's and 350D's now I've picked up recently.
As I understand it, the TRX350's in 86 and 87 use one CDI
The 87 350D uses a different CDI that is ONLY used on the 1987 350D
The 88-89 350D's use a third CDI
Is your 87 a TRX350 or TRX350D? Should be a label on the front of the frame in the center. or you can simply tell by whether or not you have a fuel gauge in the fender (the D stands for digital fuel gauge)
Fenders might have been swapped at some point, so I always look at the sticker.
Scot1966 has what you need. PM him.
