650 code blinks 11 times please help
16549 Views 10 Replies 6 Participants Last post by  jeepwm69
I bought a 03 rincon bout a month ago guy said he put clutches in it and never acted right again it's goes to half rev and will run about 20mph on flat f
Ground I had a small motors guy check it listen to it and he referred me to buy a parts 05 rincon good motor and trans just had some frame damage up front I got it home and did a complete motor swap I changed the ECM the tp sensor and I still have the same problems half throttle 20mph top speed
1 - 11 of 11 Posts
welcome to the forum !!!
toodeep will be along to give you a hand (sorry man i don't know much about them )
Welcome to the forum. That code is for the throttle position sensor. Did you set it with a meter when you swapped it?
No it's was doing this before I swapped the motor and trans so I just started with ECM and tps sensor I've been told how to program it but no set with a meter thanks for the fast response
It idles fine there just something that won't let it open up it had to be electrical I will try what I've learned tonight when I get off work thanks again for the advice
Ok I got to fooling with it today and I can use the ESP to shifted threw 3rd when I'm parked but as soon as I give it gas it startes blinking "--" auto and esp is the samething I've tried reprogramming the ECM 20 times and I keep getting the same "--" I disconnected the battery and that didn't work
Check the TPS and make sure it is set correctly and go from there.
Thanks will do how do I go about calibrating the tps I swapped them out and I was told you had to set a certain way
I just fixed mind,, code 11.. throttle sensor.. I put a new carburetor on and didn't set the throttle sensor. gave me the 11 code.. adjusted the sensor all the way and worked perfect. Now my gears change in manual and auto.. That sensor is on the left side the carburetor, where the wires plug in.
How do you set the tps on the carb? I'm having this same issue
Go here, download the factory service manual
https://drive.google.com/drive/folders/1GcqS65GYd3yFmEAGsI7LP-eZp2jMRVJU
TPS setup is on page 24-32
1 - 11 of 11 Posts
