Mine was giving me 3 flashes and it was the connection into the main computer thing under the front plastic.
I probably would try disconecting the pos battery side and then see if that resets anything, you may also want to check the voltage and continuity in the clutch speed senser and the FCC But I am just telling you where I might start
Honda Mechanic may have a little more insight to you problem
