4x4 Question
3683 Views 12 Replies 8 Participants Last post by  seltzer
Sorry to barrage you guys with what may seem like dumb questions, but you all are experts when it comes to these machines!!
While digging myself out of a mud hole last week in my Foreman, my bro-in-law noticed that my front wheels would alternate spinning, left, right, left, right and so forth. Now, on our buddies Rancher, he would come out of the same mud hole, both front tires spinning...with no problems. I seem to get stuck in mud way more than he does....is this normal for my front wheels to alternate drive????
BTW, in case it matters...it is a '05 Foreman S...selectable 2/4 wheel drive.
1 - 13 of 13 Posts
yeah the power goes to the tire with the least resistance, kinda opposite how it should work, but it keeps stuff from breakin (also known as the honda 3 wheel drive)
Makes sense. My buddy was probably just hitting the hole harder/faster than me and had better traction coming out. I am still in the "*****-foot around" stage of riding. It will grow on me as I progress!!!
Thanks for the quick reply Robb!
You can install a locker to solve that problem but they are pretty pricey and they tend to break things much eisier
one trick that i have used occasionally is when one front is in the air and spinning and the rears are getting no traction, pump the front brake while staying on the throttle and sometimes it will send enough power to the other front to pull you out. last week i had to do exactly that while in the snow.
sorry to hi-jack but "last week while in the snow?" that's crazy to think about down here in ga.I don't think satan himself could bear the heat we've been having.
this picture was taken on the last day of august 2005 in the sierra nevada mts at about 9800 ft elev
Man.....If that aint a great picture...WOW
QUOTE ("shooterman":2s2v4stt)
I shall give that a try. Thanks. Down the road I will look into some better tires for the beast...the stockers don't clean themselves very well.
another alternative to 3 wheeling is to drag the front brakes while giving it some throttle. This equalizes the resistance of the front wheels and they will start to spin again.
i never thought of that thanx
The Honda traxlok is supposed to send power to the wheel with the most traction. Not sure though, every time I've had mine in 4wd all four turn. I have not done it yet but I've read that the traxlok system works better if you replace one ounce of gear oil with the GM limited slip gear oil.
QUOTE ("wirenut":fj7lvevp)
Hmmm..never heard of that before. I will look into it. I have heard that stuff is made from Whale sperm!!!!
I bought the Honda 80/85 hypoid gear oil for it today, I plan on changing both dif's fluid this week. I have 275 miles on it, through some mud and water. Shall be interesting to see the condition of the lube in it.
1 - 13 of 13 Posts
